Old 10-26-2016, 07:59 AM
bbb bbb is offline
Head orientation data
Hi Jeff,
How does Vizard translate the head direction from the Oculus DK2 to shifts in the view? I need to know the head orientation of participant in the experiment as I already asked you about (http://forum.worldviz.com/showthread.php?t=5834) and i thought that maybe i can get it the way Vizard does.
Thanks.
Old 10-26-2016, 06:05 PM
Are you using a vizconnect configuration file to connect to the Oculus? If so, viewpoint updates are based on parent nodes in the scenegraph. For example if there is both a tracker and a transport in the scenegraph, the final viewpoint orientation in global coordinates is equal to the transport orientation plus the tracker orientation.
To get a handle to the oculus tracker in a vizconnect based application, use the getTracker command with the tracker name defined in the vizconnect GUI:
oculusTracker = vizconnect.getTracker('head_tracker')
You can get a handle to the viewpoint orientation using the following:
view = viz.MainView
Use vizact.onupdate to register a function and get the tracker or viewpoint data each frame:
def printData():
	print 'tracker orientation', oculusTracker.getEuler()
	print 'view orientation',view.getEuler()
vizact.onupdate(0,printData)
Adjusting starting head orientation of viztracker surf3rguy Precision Position Tracker (PPT) 4 01-06-2012 06:47 PM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 05:30 AM
Head tracking logging & realtime data tmcw Vizard 2 08-18-2007 11:31 AM
tracking head rotation orientation VAmanda Vizard 3 09-21-2005 05:57 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 09:48 AM
