Old 10-19-2016, 01:40 PM
mihirradia mihirradia is offline
Zspace Stylus
I have a CAD model that I have uploaded in the virtual environment. Now I want to use the zSpace stylus to pick up the object by the pressing the primary button. The stylus need to project a beam and at the end of the beam a sphere where it interacts with the object. How do I achieve this?
Old 10-21-2016, 05:20 PM
I'm getting this error "ERROR: Link failed (destination linkable is invalid)". what is the cause of this error? How can I solve this?
Old 10-25-2016, 12:55 PM
The zSpaceExample.py script included with Vizard shows how to use the stylus to pick up objects. Does that work the way you want? If so, you could modify the script to load your model instead.
Flickering of the z space environment when pressed with z space stylus mihirradia Vizard 4 07-01-2016 10:47 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 03:28 PM
Problem reading VRPN info from ZSpace davev Vizard 2 10-24-2012 12:45 PM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
