Old 07-14-2016, 01:37 PM
tokola tokola is offline
Pause and resume simulation without user input
Hi Jeff (or anyone else),
I'm trying to pause and resume the simulation automatically, based on time delay. However, since the timers stop working during pause(), I don't know how this can be accomplished. Neither viztask or any other timer-based solution works. How can I call play() at a predefined time after pause() has been called?
What I want to do is resume the simulation a) after a video finishes playing and b) after vizhtml receives input from clients. In the latter case there is a workaround, to receive the trigger for play() from one of the clients, although by being network-dependent I run the risk of blocking playback in case there's a network glitch.
Any help will be greatly appreciated!
Old 07-15-2016, 05:39 AM
The viz.tick command will still update when the timers are paused. You can check the viz.tick value from a function that's registered with the vizact.onupdate command:
import vizinfo
info = vizinfo.InfoPanel('paused for 5 seconds')
viz.pause()
def updateFunction():
	print 'frame time',viz.getFrameTime()
	print 'viz.tick',viz.tick()
	if viz.tick() > 5.0:
		viz.play()
		info.setText('playing')
vizact.onupdate(0,updateFunction)
Old 07-15-2016, 03:40 PM
Thanks Jeff, that could do the trick.
A side question is this: is there a way to pause timer events but still have actions running?
Old 07-16-2016, 05:21 AM
Instead of pausing the simulation time, you could pause timers individually. This will not affect running actions:
timerHandle = vizact.ontimer(0,timerFunction)
#disable timer
timerHandle.setEnabled(viz.OFF)
#enable timer
timerHandle.setEnabled(viz.ON)
Old 07-17-2016, 12:44 PM
Yeap, I knew this.
However I've got schedulers and starttimer() events occurring randomly during playback, so it's really hard to address specific timers. Pause() takes care of all these, freezing their operation without cancelling them, but also deactivates animations (actions). I guess there's no other way around it, right?
Old 07-18-2016, 02:37 AM
Erikvdb Erikvdb is offline
Originally Posted by tokola View Post
Yeap, I knew this.
Just keep a list of active timers and start/stop them on pause
Schedulers may be a bit more tricky, but you could use some while loops to wait when the game is paused.
Old 07-18-2016, 03:44 PM
Thanks Eric.
I'll take the advice from both of you and make it work the way I want.
