Old 07-02-2016, 01:18 PM
Eugene Eugene is offline
Timer for experiment
Hi Jeff,
I'm using Vizard to run an experiment. I used viz.tick() to register a startTime for an action e.g. turn ON the power of a system. I added a delay for the simulation to complete the process. Recently, I added viz.pause and viz.play to my program so that I could pause the simulation at any time to ask questions. However, I realized that viz.tick() is still running even when I pause the simulation. As my progress bar update is based on viz.tick() it did not pause as I expected.
Is there ways to stop viz.tick() when I pause the program or would you recommends I use other methods to register my time.
Thank you.
def displayProcessTime():
global RemainingTime
global StartTime
global EstimatedTime
global Time
print 'displayProcessTime function'
if 'SHUTDOWN' not in instrList[currentStep[0]][0]:
StartTime = viz.tick()
EstimatedTime = StartTime + int(timing[instrument][1])
#RemainingTime = EstimatedTime - viz.tick()
EstimatedTime = StartTime + int(timing[instrument][2])
while viz.tick() <= EstimatedTime:
print 'SSRMS PB'
yield viztask.waitTime(0.5)
UpdateProgressBar()
myBar.set(ProgressBarLevel)
Old 07-07-2016, 03:54 AM
Try using the viz.getFrameTime command. The frame time will not increase when viz.pause is called:
Press 1 to play
Press 2 to pause
import vizinfo
vizinfo.InfoPanel()
viz.pause()
def printTime():
	print viz.getFrameTime()
vizact.ontimer(0,printTime)
vizact.onkeydown('1',viz.play)
vizact.onkeydown('2',viz.pause)
Timer events within a Tkinter class kevin Vizard 2 07-29-2011 12:10 PM
Question about Vizard Expiration Timer Rate mizutani_jun Vizard 2 02-23-2011 09:13 PM
Timer event in viztask GiudiceLab Vizard 1 10-07-2010 12:14 PM
timer question again Elittdogg Vizard 3 10-18-2007 10:29 AM
Timer speed Jerry Vizard 1 12-08-2006 11:01 AM
