Old 06-30-2016, 04:44 AM
rajnishv rajnishv is offline
Smile Regarding Vizard+LeapMotion Hardware Controller Integration
Hi everyone,
If you are using leap motion controller(with leap motion service installed) on the PC,then i have made Vizard to get data from leap motion controller (via leap motion service) and tracked.
The data can also be applied on grabber tool in realtime,with vizconnect grabber tool linking with the data of leapmotion,and then can be oreinted a real hand with a grabber tool.
Pls see to the attached file of the leapmotion controller+Vizard file..
Make sure u have each and every file of SDK and modules in path.
Thank you!!
Thanx & reagrds
Mr.Rajnish Vishwakarma
Software Developer for Mobile,AR,VR
Old 07-27-2016, 12:35 PM
Originally Posted by rajnishv View Post
Hi everyone,
Thank you!!
Thanx & reagrds
Hi, there is some error comes out "DLL load failed: ֒һսָ֨քģࠩc"
Old 07-27-2016, 02:48 PM
Hi everyone,
Thank you!!
Thanx & reagrds
ImportError: DLL load failed: The specified module could not be found.
it comes with error like this? how to solve it?
Old 07-28-2016, 06:25 AM
Make sure you are having the all the Python Modules of Leap Motion in path with the Vizard Script.
Note-(You can open all the Python Modules of Leap Motion in Vizard too)
Thank You!!!
Regards
Software Developer
Xenium Digital Pvt Ltd,Mumbai
Old 07-28-2016, 01:45 PM
Thank You!!!
Regards
Software Developer
do you know how to get the position data of individual hand except print it out?
As I change the code in your file? The Vizard crashed down.
Old 08-08-2016, 02:17 PM
Hi everyone,
Thank you!!
Thanx & reagrds
can you post some sample code about how to orient with real hand model?
Old 09-03-2016, 01:58 AM
Thanx for ur post haohaoxuexi1
I am still in the development mode and Ill provide you the PYTHON code to get the access to the orient with real hand model.
Thanx & reagrds
Old 11-23-2016, 10:11 AM
sumanth053 sumanth053 is offline
Registered User
hi rajnishv,
do you have any sample code on how to implement leap motion data to a virtual hand in vizard.
Need benchmark app, to pick best hardware for vizard? Matt Wheeler Vizard 1 11-16-2008 01:38 PM
