Old 06-29-2016, 06:20 AM
question about BUTTON_EVENT
checkbox = viz.addCheckbox(pos=(0.5,0.5,0))
def onButton(obj,state):
if obj == checkbox:
if state == viz.DOWN:
print 'Checked'
pass
viz.callback(viz.BUTTON_EVENT,onButton)
checkbox2 = viz.addCheckbox(pos=(0.5,0.5,0))
def onButton1(obj,state):
if obj == checkbox2:
print 'Checked'
pass
viz.callback(viz.BUTTON_EVENT,onButton1)
when i write the code as above, why is the system only execute the later BUTTON_EVENT but not both of them?
If i have two checkbox, should i put the judging condition in the same function?
Old 06-29-2016, 09:20 AM
I think this is expected behavior when two buttons are stacked on top of each other. What is the reason for having two buttons in the same position?
You could use the vizact.onbuttondown command and register a callback function for each button.
<multimedia:image>.setImageData question shivanangel Vizard 0 01-28-2014 07:43 PM
question about NVIDIA 3D vision Weihua An Vizard 5 08-02-2010 06:49 AM
how to invoke command line question billjarrold Vizard 2 01-11-2010 08:51 AM
Stereo Overlap question JMOwens Vizard 2 01-08-2008 08:54 AM
