Old 05-20-2016, 01:02 PM
helena35 helena35 is offline
Fade in and fade out an audio file
Hi all,
I would like to create a spatial sound atmosphere. I made a script (very rudimentary) in which whenever the user turns the head 20 degrees, hears a different file (therefore I have 18 audio files in the scene, played simultaneously; one with volume =1, and the rest with volume = 0) Is there a way to made a fade out of the previous file and fade in of the new one in an overlapping sector of 10 degrees:
0-10 degrees: file 1 volume 1 (rest volume 0)
10-20: file 1 fade out, file 2 fade in (rest volume 0)
20-30: file 2 volume 1 (rest volume 0)
30-40: file 2 fade out, file 3 fade in (rest volume 0)....
Maybe a way of changing the volume gradually in these junction circular sector regarding the position of the head?
Thanks in advance
Old 05-20-2016, 01:19 PM
I forgot to say that the user will be in a fixed position within the scene, and will only have the possibility of turning 360 degrees in this fixed position without displacements.
Old 05-23-2016, 10:29 AM
You could use the head tracker euler values to trigger custom events. There isn't built in sound fading so you would have to write a simple sound fader that reduces volume over a small period of time.
Old 05-24-2016, 03:09 AM
Erikvdb Erikvdb is offline
In this case the sound shouldn't fade over time, but rather over a number of degrees. So you could write a fader that decreases the volume of file1 with 0.1 with every degree over 10 (until volume is 0), etc.
Old 05-29-2016, 02:57 PM
Thanks both for your answers...
Any idea of how to write a fader that decreases the volume? Is there any tool with which it can be done? I am new in Vizard and I have no idea on how to make it in a simple way...
Old 05-30-2016, 06:04 AM
You could use vizact.onupdate to register a function that's called every frame. In that function, get the viewpoint orientation and based on that value play and fade audio files. Here's an example:
#0-10 degrees: play file 1
#10-20: fade out file 1, fade in file 2
#30-40: fade out file 2, fade in file 3
#50-60: fade out file 3, fade in file 4...
viz.addChild('piazza.osgb')
intervals = [0,10,30,50]
audioFiles = ['bells.wav','fountain.wav','conversation.wav','birds.wav']
#create a list of audio objects, set to loop mode
audioList = []
for file in audioFiles:
	audio = viz.addAudio(file)
	audio.loop()
	audioList.append(audio)
def fadeAudio():
	yaw = viz.MainView.getEuler()[0]
	print yaw
	for index,interval in enumerate(intervals):
		if interval < yaw <= interval + 10:
			# if first iteration only play first audio file
			if index == 0:
				if 	audioList[0].getState() in [viz.MEDIA_STOPPED,viz.MEDIA_PAUSED]:
					audioList[0].play()
			# for all others play next file and apply fades
				if audioList[index].getState() in [viz.MEDIA_STOPPED,viz.MEDIA_PAUSED]:
					audioList[index].play()
					audioList[index].volume(0)
				fadeInValue = (yaw-interval)/10
				fadeOutValue = 1.0-fadeInValue
				audioList[index].volume(fadeInValue)
				audioList[index-1].volume(fadeOutValue)
				# pause audio if volume is close to 0
				if fadeOutValue < 0.01 and audioList[index-1].getState() == viz.MEDIA_RUNNING:
					audioList[index-1].pause()
vizact.onupdate(0,fadeAudio)
#Spin the view to 60 degrees at 2 degrees/s.
spinAction = vizact.spinto(0,1,0,60,2)
viz.MainView.runAction(spinAction)
cinematic fade to black? billjarrold Vizard 4 12-23-2009 11:09 AM
