Old 04-25-2016, 12:37 PM
VizMars VizMars is offline
pylink world rendering
Hi!
I use a Eyelink Eye Tracker (SR Research) for the eye tracking and pylink as a communication interface in my experiment.
When I call pylink.doTrackerSetup() to calibrate the eye tracker, the rendering of my world is interrupted (i.e. the application window displays a splash screen) and Vizard needs time to reload the world after the calibration.
Does anyone know how I can fix this (e.g. by pausing the rendering and resuming it after the calibration)?
Old 04-25-2016, 10:13 PM
Is the issue that everything is loaded twice, before and after the calibration? If so, perhaps the script could be setup so that models are loaded only after the calibration is complete.
Old 04-26-2016, 02:26 AM
Yes, that would be possible.
Is there a way I can pause the rendering process?
Old 04-26-2016, 04:11 AM
Can you post a simple example script that reproduces the issue? Is the issue that the virtual environment is loaded and running, the eye tracker calibration is started, and the Vizard splash screen is shown a second time?
Old 05-09-2016, 06:43 AM
Yes, that's the problem.
This simple example reproduces the issue. You can skip the calibration by pressing the Esc key, then pylink.closeGraphics() closes the graphic and the Vizard splash screen is shown a second time.
import pylink
SIZE = ( viz.getOption('viz.monitor.width', type=int), viz.getOption('viz.monitor.height', type=int) )
viz.go(viz.FULLSCREEN|viz.QUAD_BUFFER)
eyelinktracker = pylink.EyeLink(None)
eyelinktracker.sendCommand("screen_pixel_coords =  0 0 %d %d" %(SIZE[0], SIZE[1]))
#eyelinktracker.sendMessage("DISPLAY_COORDS  0 0 %d %d" %(SIZE[0], SIZE[1]))
pylink.openGraphics((SIZE[0], SIZE[1]),32)
eyelinktracker.doTrackerSetup()
eye tracker, pylink
Augmented Reality: virtual world not overlapping real world correctly Vaquero Vizard 7 04-15-2016 01:14 AM
3D world editor Ploep Vizard 2 05-03-2012 02:25 AM
rendering level shahramy Vizard 1 07-26-2010 12:12 PM
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 05:33 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 03:44 PM
