Old 03-24-2016, 06:44 AM
Martina Martina is offline
vizdlg Panel Size
I'm looking to get the size of an auto-scaled vizdlg Panel (I need its length and height). Is there a way to do this?
Best,
Martina
Old 03-25-2016, 08:45 PM
I'm not sure but will look into it. Can you post example code you're using to scale the panel?
Old 03-27-2016, 10:22 PM
Use the Panel.getBoundingBox method to get the panel dimensions:
import vizshape
import vizdlg
myPanel = vizdlg.Panel(align=viz.ALIGN_LEFT_BOTTOM)
row = vizdlg.Panel(layout=vizdlg.LAYOUT_HORZ_BOTTOM,border=False,background=False,margin=0)
row.addItem(viz.addText('Textbox'))
textbox = row.addItem(viz.addTextbox())
myPanel.addItem(row)
circle = vizshape.addCircle(parent=viz.ORTHO,scale=[20,20,1],color=viz.RED)
def showPanelDimensions():
	box = myPanel.getBoundingBox()
	width = box.width
	height = box.height
	print width,height
	circle.setPosition([width,height,0])
myPanel.setPanelScale(2)
vizdlg
Draw order of vizinfo Panel mape2k Vizard 2 10-08-2015 02:59 PM
Changes in vizdlg or vizact in Vizard 5? mape2k Vizard 2 12-10-2014 05:58 AM
Problem Vizdlg panel draw order Chapre Vizard 1 05-17-2011 02:29 PM
vizdlg Panel: Add and remove disbeat Vizard 2 02-08-2011 12:44 PM
vizdlg dialog components on a single panel Chapre Vizard 3 11-20-2010 02:47 PM
