Old 01-09-2016, 06:51 AM
SivaKartheek SivaKartheek is offline
Question Regarding the visibility of avatars
Hello Everyone,
I have a problem with the visibility of avatars the same code is given below for single avatar
PHP Code:
import viz
import vizact
viz
.go()
viz.setMultiSample(4)
viz.MainWindow.fov(70)
viz.MainView.setPosition(0,3,-5.9)
male =addAvatar('vcc_male.cfg')
x=[-0.65, -0.1, -0.65, -0.1, -0.66#x-stores the position of all points in xdirection here i have given only little data
y=[5.865.895.775.795.68]#lly for y
walkspeed=[1.39,1.38,1.5,0.8,0.6]
def walkAvatars():
     for
i in range(len(x)):
walk=vizact.walkTo([x[i],0,y[i]],walkSpeed=walkspeed[i])
male.addAction(walk)
            if
i==3:
male.visible(viz.OFF)
vizact.onkeydown('m',walkAvatars
My question is that the avatars are not visible before the finishing the walking action of the avatars
can anyone help me how i can rectify this problem in such a way that the avatars are not visible after finishing the walking action
Thanks and Regards
SivaKartheek
Old 01-11-2016, 06:11 AM
Take a look at the viztask documentation in the reference and tutorial sections of the Vizard Help. You can wait for the walk action to finish before changing the avatar's visibility:
import viztask
male = viz.addAvatar('vcc_male.cfg')
x=[-0.65, -0.1, -0.65, -0.1, -0.66] #x-stores the position of all points in xdirection here i have given only little data
y=[5.86, 5.89, 5.77, 5.79, 5.68]#lly for y
def walkAvatars():
	yield viztask.waitKeyDown('m')
	for i in range(len(x)):
		yield viztask.runAction(male,walk)
		if i==3:
viztask.schedule( walkAvatars() )
Old 01-13-2016, 07:48 AM
thankyou very much for your help jeff
With BestRegards
SivaKartheek Sreeram
walking action of avatars SivaKartheek Vizard 1 12-14-2015 10:58 PM
problems with walking women avatars armo Vizard 6 04-07-2015 07:38 AM
avatars dig Vizard 4 09-20-2007 03:29 PM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 04:06 PM
