Old 10-23-2015, 11:21 PM
jai jai is offline
consecutive images render
Hello Jeff,
Suppose i want to render more than 100 consecutive images in vizard as an animation..
How to do this?
Old 10-26-2015, 12:09 PM
Do you want to make a movie out of textures? If so, take a look at the following:
http://docs.worldviz.com/vizard/#exa...x_lighting.htm
What's the resolution of the images?
Old 11-26-2015, 08:51 PM
jai jai is offline
Hello jeff,
These are satellite images. Normal resolution is 2k x 2k
Old 11-27-2015, 12:33 AM
Seadna Seadna is offline
Also is it possible to do this with a panorama i.e. 360 degree video.
Old 12-02-2015, 04:02 PM
Each frame has to be decompressed to RGB and uploaded to the GPU and then applied as a texture in Vizard. If the amount of image data exceeds the GPU memory then you could have framerate drops.
Old 12-02-2015, 04:19 PM
Do you have a spherical video or images that you want to apply in sequence?
Old 12-06-2015, 11:25 PM
jai jai is offline
thanks jeff, will try ..
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 06:45 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 10:20 AM
To Masaki regarding render nodes surf3rguy Vizard 1 04-17-2012 05:37 PM
