Old 07-22-2015, 02:02 PM
Goof Goof is offline
HMD view warp
I'm using an nVisor SX60, but any viewed image is slightly warped.
That is, straight lines at the top of the screen bend into a "smile" shape, while straight lines near the bottom bend into a "frown", and the same effect on the sides, like the opposite of an image seen through a fisheye lens.
This causes all sorts of scene warping as you view a 3d scene with the headset on. This happens when simply viewing the desktop through the HMD as well.
What could this be? An issue with the HMD? An optical illusion? We have two, both have the same issues.
Old 07-23-2015, 03:35 PM
Are you using an nvis command to configure the display output in Vizard or adding the nvis display through vizconnect? Try the following test script:
import nvis
viz.go(viz.FULLSCREEN)
nvis.nvisorSX()
gallery = viz.addChild('piazza.osgb')
Old 07-24-2015, 09:34 AM
Generally I just use viz.go(viz.FULLSCREEN|viz.STEREO) to send the image to the HMD.
Tried the test script, it has the same effect.
I also used viz.fov() and changed the field of view, but that didn't get rid of the warping either.
Is it just the shape of the lenses?
Old 07-24-2015, 12:05 PM
Since this happens with any image I would suggest contacting nvis support for suggestions.
Wide-angle view Brett Lindberg Vizard 8 09-04-2009 04:57 PM
View nlfrnassimi Vizard 0 03-17-2009 02:01 AM
View nlfrnassimi Vizard 4 03-12-2009 05:25 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 09:58 AM
keeping a 3d object in front of the view tavaksai Vizard 1 07-07-2004 09:33 AM
