Old 07-16-2015, 10:19 AM
parpar parpar is offline
Registered User
scale adjustment
hi everyone...
I have a small question...
when I run my models on my pc screen, they work properly... the scaling is right, I am on the ground and I walk on the ground. but when I run it on multi screen then the scaling is not right. everything is so much bigger except me. I am as big as a pigeon. I am not on my chosen starting point. I'm whether under the ground or in the sky flying.
why is it happening and how can I fix it ??
Old 07-20-2015, 04:27 PM
Can you post example Vizard code that reproduces the issue?
scale problem using <node3d>.parent() Chapre Vizard 1 09-27-2010 11:23 AM
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 07:48 AM
scale of image increase over time durf Vizard 1 05-08-2009 09:53 AM
