Old 06-08-2015, 10:53 AM
tokola tokola is offline
Multi-line text node
Is this possible? I couldn't find a way to insert special characters to a text node (e.g. TAB or RETURN).
Old 06-08-2015, 11:37 AM
Here's example code that uses the newline character to create multiple lines in a text object:
gallery = viz.addChild('gallery.osgb')
text = viz.addText('line 1\nline 2\nline 3',parent=viz.SCREEN,pos=[0.5,0.5,0])
text.alignment(viz.ALIGN_CENTER)
Old 06-08-2015, 01:19 PM
Thanks Jeff. I actually just found it and wanted to post it.
Is there a way to insert other special characters, like TABs?
Old 06-10-2015, 04:19 AM
mape2k mape2k is offline
Hello tokola,
didn't you asked the exact same question in another thread just a week ago?
There I stated that using "\t" should insert a tab into your string.
Best,
Johannes
Old 06-10-2015, 09:15 AM
I am so sorry. You're absolutely right. I totally forgot about it. I think dementia is on the way
I'll probably delete one of the two (if possible) to avoid unnecessary clutter of the forum.
input from a text file dig Vizard 5 10-20-2013 01:20 AM
OSG Text Node Additional Parameters pcatalano Vizard 2 11-01-2011 07:45 AM
multi line text boxes mjabon Vizard 2 07-16-2009 11:37 AM
Informationboxes with text snoopy78 Vizard 3 07-16-2009 10:23 AM
I cannot show wrl file with text node sled Vizard 3 06-25-2003 07:52 AM
