Old 05-17-2015, 01:36 AM
mike66 mike66 is offline
Registered User
Dropdown list - can't select with mouse
I have a drop down list on screen with several items, I can select an item with the keyboard however cant see to select the item with the mouse.
ver 5.1 32-bit
Regards
Old 05-18-2015, 10:16 AM
Can you post example code that replicates the issue?
Mouse bug in V3 and V4 Renato Lima Vizard 2 05-11-2011 07:38 PM
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 07:25 PM
Mouse pointer problem Albert Russel Vizard 2 02-21-2011 02:10 AM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 11:25 AM
Navigating an avatar using mouse position(2D) in 3D environment james007 Vizard 1 10-16-2009 12:29 PM
