Old 05-02-2015, 02:16 PM
MissingAFew MissingAFew is offline
Updating a Postprocessing effect
I'd like to be able to modify and update a postprocessing effect in a loop for a particular effect. Specifically, I'm wanting to modify BulgeAmount such that it loops and interpolates between -0.5 and 0.5:
effect = BulgeEffect(BulgeAmount)
vizfx.postprocess.addEffect(effect)
I tried using the director function to create a new thread and have it loop separately from the main thread but it crashed. This is the code I tried:
import viztask
import vizfx.postprocess
from vizfx.postprocess.distort import PincushionEffect
def UpdateDrunkEffect():
	DrunkValue = 0
	Modulate = True
	Length = 60
	while True:
		if DrunkValue <= 0:
			Modulate = True
		if DrunkValue >= 1:
			Modulate = False
			Length -= 1
		if Modulate:
			DrunkValue += .01
			DrunkValue -= .01
		effect = PincushionEffect(DrunkValue)
		if Length == 0:
			effect = PincushionEffect(0)
			break
viz.director( UpdateDrunkEffect )
Is there a better way to do this that I'm just not thinking of? How can I go about changing the postprocessing effect in a loop without it freezing the application?
Old 05-04-2015, 02:37 PM
Here's an example that uses the viztask.waitCall command to call effect.setBulge and waits until the vizact.mix parameters are complete.
import viztask
viz.addChild('gallery.osgb')
from vizfx.postprocess.distort import BulgeEffect
effect = BulgeEffect(0,radius=1)
def BulgeTask():
	increase = vizact.mix(-0.5,0.5,time=2)
	decrease = vizact.mix(0.5,-0.5,time=2)
	while True:
		yield viztask.waitCall(effect.setBulge,increase)
		yield viztask.waitCall(effect.setBulge,decrease)
viztask.schedule( BulgeTask() )
Old 05-07-2015, 09:58 AM
Thank you Jeff! This is exactly what I was trying to do. You make my life easy.
anaglyph effect at front view of cave g.vannan Vizard 1 02-03-2015 05:29 AM
Updating object color sxu04 Vizard 4 01-04-2012 06:47 AM
Peek Effect in Inspector pcatalano Vizard 1 03-17-2011 03:44 PM
special effect shahramy Vizard 1 06-14-2010 03:22 PM
How can I do the flip effect of poker? superantTTY Vizard 2 05-27-2010 01:15 AM
