Old 03-31-2015, 03:10 PM
adhocdown adhocdown is offline
Unhappy Orientation Gone Awry
When we initially calibrate the PPT, our orientation is perfect. However, after the first run the orientation changes, seemingly at random.
For example, when the person attempts to walk straight, she will move to the right or completely backwards in the environment.
As a side note, we are transferring tracking data wirelessly, but latency is not an issue.
Old 04-01-2015, 05:01 AM
Can you describe how you are getting the orientation data? Is it with an inertial sensor or PPT Eyes?
Old 04-04-2015, 01:30 PM
We receive information via the HMD (Oculus Rift), which uses an inertial sensor.
Old 04-14-2015, 03:34 PM
If you're getting yaw drift you can correct that by adding the optical heading plug-in in vizconnect. This setup requires that you have two PPT markers mounted above the HMD.
Old 10-07-2015, 11:14 AM
johnallen johnallen is offline
I have this same problem and I'm considering 2 possible solutions.
1/ I have 6 tracking lights/markers in all but usually only use one for tracking the participant's head so have I understood you correctly that I could use two of my spare ones to orient the yaw for the rift? (in a similar way to your eyes 2014 product?)
I usually try to use vizconnect to configure my hardware setup. Can you advise how I could integrate my markers with this please for yaw control? and how I get Vizard to take the yaw settings from the markers but to take the pitch and roll setting from the rift.
Also, should I always fix them a set, fixed separation?
2/ Or, alternatively, I have a spare intersense wireless inertiacube3. Would I be better to get Vizard to use this for the yaw, pitch and roll settings and to use the rift as a dumb display. Again, advice on configuraton in Vizconnect would be much appreciated.
I would favour whichever approach gave me the best responsiveness.
John
Old 10-08-2015, 04:18 PM
To use optical heading in vizconnect, go to the trackers tab and:
1) Add the two PPT trackers
2) Add the orientation sensor of the rift
3) Add the optical heading tracker and specify the left/right position trackers, orientation tracker, and distance between position trackers
The inertiaCube3 may also have the same drift. However, intersense provides two calibration procedures with their ISDemo software which may help reduce or eliminate it.
finicky, inconsistent, offset, orientation, ppt
System stopped recognizing position (while orientation still works) royb Vizard 2 11-06-2013 07:00 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 05:30 AM
Loading OSG models and orientation Joran Vizard 4 06-18-2009 06:43 AM
orientation question whj Vizard 3 01-21-2009 12:22 PM
(beginner) calculating orientation change with eulers astull Vizard 16 02-22-2007 10:45 AM
