Old 03-17-2015, 02:43 PM
adhocdown adhocdown is offline
Question Two HMDs in a single environment
How would you go about setting up two HMDs to work simultaneously in a single Vizard environment? Will we have to override some functions within Vizard?
Old 03-18-2015, 01:13 AM
What kind of HMDs are being used? Are you running off a single machine or two machines? Will the users be able to see each other represented as avatars?
Old 03-18-2015, 02:28 PM
We are using two Oculus Rifts (DK2) on a single machine and the users will be able to see each others' avatars within the environment. Thanks for the help!
Old 03-18-2015, 02:42 PM
Actually, would you recommend using a single or two machines? We are trying to have two, immersed participants collaborate with each other within a single environment in order to accomplish a given task.
Old 03-21-2015, 12:24 AM
Take a look at the networking section of the Vizard Help and the networking tutorial. This setup would work well with two machines on a local network.
hmd, multiple, setup, simultaneously, two hmds
random walk in piazza environment maya Vizard 7 01-15-2014 05:58 AM
drives two walls with a single PC and an nVidia graphics card su.298@osu.edu Vizard 1 03-30-2012 09:53 AM
Multi User Environment moneim230 Vizard 5 05-17-2011 06:56 PM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 09:21 AM
importing a single WRL with many objects. giancamati Vizard 3 12-18-2006 02:13 PM
