Old 03-16-2015, 11:13 AM
vserchi vserchi is offline
update sequence animation speed
Hi, I am trying to interactively update the speed of certain objects animations (sequences of animation) in my virtual reality. At the change of the variable "speed" I need that the speed of translation of my objects accordingly changes too. In the following code there is a a very simplified example of what I am trying to do.
viz.fov(60)
#Add the ground plane
ground = viz.addChild('ground.osgb')
#Move the viewpoint back
viz.MainView.move([0,0,-7])
ball = viz.add('beachball.osgb')
ball.setPosition(0,1,0)
ball1 = viz.add('beachball.osgb')
ball1.setPosition(0,0,0)
myAction1 = vizact.moveTo([ball.getPosition()[0], -1,  ball.getPosition()[1]],speed=1) # Definition of the animation of the road (custom function that manages its resume defined from line 364 to line 439
myAction2 = vizact.moveTo([ball.getPosition()[0], ball.getPosition()[1], ball.getPosition()[2]],[ball.getPosition()[0], 4, ball.getPosition()[1]],speed=1)
myAnimation = vizact.sequence(myAction1, myAction2, viz.FOREVER)
myAction3 = vizact.moveTo([ball1.getPosition()[0], -1,  ball1.getPosition()[1]],speed=1) # Definition of the animation of the road (custom function that manages its resume defined from line 364 to line 439
myAction4 = vizact.moveTo([ball1.getPosition()[0], ball1.getPosition()[1], ball1.getPosition()[2]],[ball1.getPosition()[0], 4, ball1.getPosition()[1]],speed=1)
myAnimation1 = vizact.sequence(myAction3, myAction4, viz.FOREVER)
ball.addAction(myAnimation)
ball1.addAction(myAnimation1)
def changeSpeed(pos):
	print str(pos), viz.Vector(ball.getVelocity())
	ball.setVelocity([0, pos, 0])
	ball1.setVelocity([0, pos, 0])
####	ball.setSpeed(pos)
####	ball1.setSpeed(pos)
slider = viz.addSlider()
slider.setPosition([.5,.5,0])
#Setup callbacks for slider events
vizact.onslider(slider, changeSpeed)
I really appreciate any help you may give me.
Valeria
Old 03-17-2015, 03:33 AM
Animation paths may work for you. You can link the ball to an animation path and then change the path's speed.
animation, dynamic, sequences, speed, update
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 08:16 AM
How to make character animation sequence wchoi Vizard 3 01-22-2010 09:35 AM
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
animation sequence pkhoosh Vizard 2 01-23-2006 09:03 AM
animation sequence shai Vizard 1 10-27-2004 11:09 AM
