Old 11-24-2014, 07:04 AM
mshukun mshukun is offline
Multiple versions on the same machine
Is it possible to install both Vizard 4.0 and 5.0 on the same machine?
Old 11-24-2014, 05:12 PM
Yes, you can install the different Vizard versions side by side.
Old 11-25-2014, 10:45 AM
Hi Jeff,
Thank you for your replay. What do you think about Oculus modules? Do you think "setZoom" works using Vizard 4.0 even after installing Oculus runtime?
EventClass used with multiple joysticks tokola Vizard 2 11-30-2012 12:51 PM
what is causing (a) slow frame rate and (b) spontaneous NVIDIA stereo off billjarrold Vizard 0 07-11-2012 01:25 PM
Multiple Cameras for AR artoolkit plugin Pho46 Vizard 3 11-10-2010 06:59 PM
Should my PPT Machine have a Vizard license? (Urgent) Brandyn Precision Position Tracker (PPT) 3 05-05-2008 11:06 AM
tracking with multiple LEDS dan12345 Precision Position Tracker (PPT) 7 04-02-2008 10:44 PM
