Old 10-01-2014, 12:28 PM
Alex Miranda Alex Miranda is offline
vizCave
Hello everyone. I'm trying developer a CornerCavern environment like that:
http://www.worldviz.com/systems/cornercave
I can't find good materials about it, and my project has stopped cause I can't evolve. Can someone help me? I was using Vizard 4, but I downloaded the vizard 5 on last week to test and I found the option "vizconnect", and this option seems good, but I would like to know how I can use something like that on the vizard 4, cause I have a license.
Thanks and Hugs!
Old 10-01-2014, 12:51 PM
You can use the vizcave module to set this up in both Vizard 4 and Vizard 5. If you use vizconnect to set this up in Vizard 5, it generates the vizcave code for you.
Old 10-01-2014, 01:46 PM
Thanks for your answer.
This code is not teaching how to use the vizCave and when I try to use it, the output show me " tracker is not defined".
I would like to understand how I can change the depth correctly, manage window, etc... This the basic that I need.
Old 10-01-2014, 02:01 PM
I solved the error!
Example code for VizCave stefs Vizard 6 01-08-2013 12:43 PM
Using vizcave without tracking pcatalano Vizard 3 01-08-2013 11:17 AM
vizcave and quad-buffered stereo michaelrepucci Vizard 7 11-29-2011 12:15 PM
Head tracking, Flock of Birds and vizcave; how do I connect them? Arandia Vizard 2 08-26-2009 05:59 PM
confusion over vizcave and viewpoint michaelrepucci Vizard 3 08-01-2008 02:54 PM
