Old 02-24-2006, 07:32 PM
kgarr kgarr is offline
csv reading
I am using this command to import a csv file
temp = [[float(val) for val in row] for row in csv.reader(file('data.csv','rUb')) ]
this reads in my data as an array of the rows in my data. How do I change it so that my data is in an array of columns of my data? Mainly, I want to be able to easily find the max and min values of each column in my data after loaded into Vizard.
Old 02-27-2006, 01:02 PM
Try the following code to transpose the list:
def transpose(m):
	return [[m[y][x] for y in range(len(m))]for x in range(len(m[0]))]
temp = transpose(temp)
