Old 07-25-2014, 04:39 PM
roobert roobert is offline
Send a message via Skype™ to roobert
Question Color
Can I change the color of the models that add in vizard?
example.
The box.wrl has Vizard is red, if I want change color How I do?
model1=viz.add('box.wrl')
model1.CHANGECOLOR(green)
Old 07-26-2014, 02:19 AM
model1.color(viz.GREEN)
Would do the trick. You can also use RGB values for all the colors that you would like, see http://docs.worldviz.com/vizard/comm...de3d/color.htm.
Old 07-26-2014, 09:04 AM
Frank Verberne.
not working your code or tell me the error
viz.setMultiSample(4)
viz.fov(60)
viz.clearcolor(viz.SKYBLUE)
edificio=viz.addChild('model/ID_1.dae',pos=[0,0,0])
edificio.color(viz.GREEN)
Result:
Old 07-26-2014, 09:22 AM
This my result:
http://bit.ly/1mPIpCY
Old 07-26-2014, 01:45 PM
The code should work for the box.wrl that comes with Vizard. I don't anything about your collada model, so perhaps an exporting issue? Check this knowledge base for more information about importing collada models in Vizard: http://kb.worldviz.com/articles/1413. The answer to your other scale question is also on that page.
change, color, model
Masking specific color on texture applied Chapre Vizard 1 05-03-2011 01:20 PM
Change textbox color? renama Vizard 2 10-19-2010 08:44 PM
trouble changing subnode (child node) color, alpha, etc. michaelrepucci Vizard 7 01-14-2009 09:38 PM
Changing the Color of On-the-Fly Objects vjosh Vizard 1 01-05-2005 12:48 AM
Fog Color bstankie Vizard 1 06-02-2004 02:59 PM
