Old 07-08-2014, 09:13 AM
Shweta Shweta is offline
Using move() and spinTo efficiently
I have created a cloud of triangles using startlayer and endlayer in a scene.
Now I want to smoothly move the viewpoint within the scene.
I do this using move and spinTo.
However, the problem now is that when I use move() and spinTo(), the triangles move along with the scene.
I want the triangles to remain fixed, which happens when we use mouse to navigate through the view.
Can someone help me with this?
Kindly find below my code:
import struct
import vizinput
import random
import socket
#The maximum amount of data to receive at a time
MAX_DATA_SIZE = 1024
#The port to send/receive data on
PORT = 4999
PORT_SEND = 5000
#Get the name of this computer
COMPUTER_NAME = socket.gethostname()
#Get the IP address of this computer
COMPUTER_IP_ADDRESS = socket.gethostbyname('localhost')
#Create a socket to send data over
OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
OutSocket.bind(('',PORT_SEND))
OutSocket.setblocking(0)
#Create a socket to receive data from
InSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
InSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
InSocket.bind(('', PORT))
InSocket.setblocking(0)
#Selection of the scene (Indoor?Outdoor)
choice = vizinput.choose('Select an environment',['indoor','outdoor','none'])
if choice == 0:
sceneIndoor = vizinput.choose('Seect a scene',['court','gallery','maze'])
if sceneIndoor == 0:
scene = viz.add('court.ive')
elif sceneIndoor == 1:
scene = viz.add('gallery.osgb')
scene = viz.add('maze.osgb')
elif choice == 1:
sceneOutdoor = vizinput.choose('Select a scene',['mountains','beach','forest','open ground'])
if sceneOutdoor == 0:
scene = viz.addChild('building.obj')
elif sceneOutdoor == 1:
scene = viz.addChild()
elif scene == 2:
elif choice == 2:
pass
#Create a layer.
viz.startLayer(viz.TRIANGLES)
viz.vertexColor(1,0,0)
viz.vertex(0,0,0)
viz.vertexColor(0,1,0)
viz.vertex(0.5,1,0)
viz.vertexColor(0,0,1)
viz.vertex(-0.5,1,0)
myTria = viz.endLayer()
myTria.setEuler(0,180,0)
#def Create_shape():
shapes = []
Number = 5000
for i in range(Number):
x = random.randint(-20,20)
y = random.randint(-20,20)
z = random.randint(-20,20)
yaw = random.randint(0,360)
pitch = random.randint(0,360)
roll = random.randint(0,360)
shape = myTria
shape.setPosition([x,y,z])
shapes.append(shape)
ver1 = shape.getVertex(0)
ver2 = shape.getVertex(1)
ver3 = shape.getVertex(2)
viz.vertex(ver1)
viz.vertex(ver2)
viz.vertex(ver3)
x = shape.getPosition()
myTriangle = viz.endLayer()
myTriangle.setPosition(x)
myTriangle.setEuler(0,180,0)
## Code for sending data
def SendData(data):
OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT_SE ND))
## Code for receiving data
def ReceiveData():
try:
return InSocket.recv(MAX_DATA_SIZE)
except socket.error:
#Insert error handling code here
pass
## May change as per requirement
vizact.onkeydown(' ',SendData,'hello there')
def CheckSocket():
#Try to receive data from socket
data = ReceiveData()
if data:
numvalues = (len(data)/ 8)
udp = struct.unpack('>'+'d' * numvalues ,data)
# Assigning the rotation and translation values
yaw = udp[0]
pitch = udp[1]
roll = udp[2]
moveSpeed = udp[3]
xPos = udp[4]
yPos = udp[5]
zPos = udp[6]
if ((yaw == 1) and (pitch == 1) and (roll == 1) and (moveSpeed == 1) and (xPos == 1) and (yPos == 1) and (zPos == 1)):
initPos = vizact.spinTo(euler=[0,0,0], speed = moveSpeed)
scene.addAction(initPos)
index = random.randint(0,1)
if index == 0:
rotation = vizact.spinTo(euler=[yaw,pitch,roll], time = moveSpeed)
scene.addAction(rotation)
rotation = vizact.spinTo(euler=[-yaw,-pitch,-roll], time = moveSpeed)
rotTime = 0;
if xPos != 0:
rotTime = xPos / moveSpeed
elif yPos !=0:
rotTime = yPos / moveSpeed
elif zPos !=0:
rotTime = zPos / moveSpeed
# Check condition to execute translation
if rotTime != 0:
translation = vizact.move([xPos,yPos,zPos],rotTime)
scene.addAction(translation)
print udp
vizact.ontimer(0,CheckSocket)
Thanks in advance.
Kind Regards,
Shweta.
Old 07-14-2014, 11:31 AM
Please see the guidelines for posting Vizard code. This will make it easier for other users to help with your code.
Old 07-28-2014, 01:54 AM
Reposting the code :
import struct
import vizinput
import random
import socket
PORT = 4999
PORT_SEND = 5000
if choice == 0:
elif choice == 1:
elif scene == 2:
elif choice == 2:
pass
#Create a layer.
viz.vertex(0,0,0)
viz.vertex(0.5,1,0)
shapes = []
Number = 5000
shape = myTria
viz.vertex(ver1)
viz.vertex(ver2)
viz.vertex(ver3)
def SendData(data):
def ReceiveData():
try:
pass
def CheckSocket():
if data:
yaw = udp[0]
pitch = udp[1]
roll = udp[2]
moveSpeed = udp[3]
xPos = udp[4]
yPos = udp[5]
zPos = udp[6]
if index == 0:
rotTime = 0;
if xPos != 0:
elif yPos !=0:
elif zPos !=0:
if rotTime != 0:
print udp
Old 07-29-2014, 05:10 PM
It's not possible to copy/paste your code and run it. The indentation has been lost and it seems the example could be simplified. Try and minimize the code so that it can be run directly without requiring a network connection. You might need to store the data in some lists to simulate what's received via the network.
