Old 03-25-2014, 05:08 PM
Ambient Occlusion using Light Baking Technique?
Your shader section doesn't cover using Ambient Occlusion.
Back in Vizard 4, I could stick the AO in the self-illumination slot and it works.
Now if I try to do this with Vizard 5 shaders or placing it in the ambient color slot, I get nothing but a washed out surface.
Once I turn off material descriptions, it works fine. But this seems like a problem if I want to mix in AO maps with all the other new features.
Ideas?
Old 03-25-2014, 06:39 PM
Hi shivanangel,
Ambient is the correct slot for it. I'm guessing you're using white as the unoccluded color, correct?
If that's the case, the issue here is that the Vizard 5 shader expects lightmaps used in the slot to be centered on a middle gray. The values in the lightmap are multiplied by 2 before being multiplied by the values of the diffuse texture. This is similar to using the "Self-Illumination Scale" exporter option for the Vizard 4 approach.
For existing maps, this can be fairly quickly fixed by running them through a Photoshop batch process that halves their values (e.g. with Levels). For new baked maps, set the range to go from black to 50% gray instead of black to white.
Old 03-26-2014, 09:15 AM
Thank you!
I'll give it a shot later today.
Learning some new things, but loving the new shader support.
~George
ambient occlusion
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 07:45 PM
Demystifying exporting light maps from 3ds Max to Vizard? dproeder Vizard 1 06-14-2013 02:34 PM
Realistic Light and Shadows Using Vizard and 3DS Max jde Vizard 4 07-13-2012 11:58 AM
Ambient light Enlil Vizard 0 05-03-2011 09:48 AM
Screen Space Ambient Occlusion chris_user Vizard 0 03-18-2011 12:36 AM
