Old 03-06-2014, 08:49 AM
ola_nag ola_nag is offline
Fastrak
I'm trying to connect Fastrak and I can not understand why I got this message:
polhemus = viz.add('polhemus.dle')
fastrak = polhemus.addFastrak(port=1,bandRate=115200)
File "<string>", line 2, in <module>
AttributeError: 'VizExtension' object has no attribute 'addFastrak'
The connection is passing via parralel port (not a usb port), and I don't believe that attribute addFastrak is not included into the standard library polhemus.dle.
Can smbd help me?
Old 03-10-2014, 10:24 PM
Try reinstalling Vizard and let us know if that helps.
Old 03-11-2014, 09:52 AM
No. The reinstallation didn't help. I still get the same error.
Besides I've tried to launch Fastrak with Vizard on the second computer and I still have the same error.
If it is useful, I'm trying Vizard 4 (evaluation version 32) on windows XP and windows 7.
Do you have some other suggestions?
Old 03-12-2014, 06:56 AM
In the code you posted it shows bandrate where it should be baudrate. Try running the following code:
fastrak = polhemus.addFastrak()
Also make sure that PiMgr is not running when you run Vizard.
Old 03-13-2014, 10:01 AM
I've tried your code. I've checked that PiMgr is not running. But I still get the same error
Old 03-13-2014, 10:22 AM
Can you please post the entire output generated when running the above script? It sounds like the polhemus plugin is not even loading, which should output an error message.
Old 03-18-2014, 09:48 AM
I have found where the problem was.
I have tried the script in the command line (interactive mode). Launching the script with the script file works fine.
Thank you very much!
Polhemus Fastrak williamchappell Vizard 11 09-28-2013 09:49 AM
Integration of Polhemus fastrak transmitter data to Basic guy free rig in maya abhilash Vizard 0 04-15-2010 11:18 PM
fastrak Steve_HT Vizard 17 07-20-2007 10:51 AM
