Old 01-29-2014, 04:53 AM
krimble krimble is offline
compiled exe won't save trials to AVI
I'm working on a project which would heavily benefit of being able to save our trials to individual AVI files (trial01, becomes trial01.avi, trial02 becomes trial02.avi, etc). I programmed it and it works fine.
However it doesn't work anymore when published to exe. Can a vizard exe generate avi files?
Yes, how?
No, why not? and is there an alternative?
Thanks for your help!
Best, Jeroen
Old 01-29-2014, 12:32 PM
masaki masaki is offline
Published EXEs are unable to generate AVI recordings. This is mentioned in the Vizard Documentation in the Publishing as an EXE section and under Limitations. You can try using a command line screen capturing software and trigger it through Vizard.
Best,
Masaki
Including DLLs outside compiled EXE davidrichens Vizard 1 10-31-2011 11:35 AM
running experimental trials fivel_lab Vizard 3 03-18-2011 03:58 PM
Record an animation in MotionBuilder, save it and apply it to NPC avatar? Josh Vizard 0 03-23-2010 09:37 PM
How to input several model files and then save one output file mspusch Vizard 1 07-15-2008 11:30 PM
Is it possible to save a vizard program as (movie) a media file? ghazanfar Vizard 5 05-07-2007 11:03 AM
