Old 01-14-2014, 08:05 PM
renderowl renderowl is offline
Oculus Rift Demos
I've been testing out the VR demos found here: http://www.worldviz.com/products/vizard/oculus and I'm finding that, out of the box, these demos are quite disorienting. It seems like the projection is askew, and I can only use the headset for about 30 seconds before becoming nauseous. This isn't an issue with my Unity builds, and Half-Life 2 has been running fine in VR mode. Any thoughts?
Old 01-15-2014, 12:21 PM
masaki masaki is offline
Hello, thank you for trying out our Oculus Demos. We're looking into the issue you're having but in the mean time, can you make sure that you're running the Oculus at 1280x800 and make sure you're not cloning the Oculus with another display? I've noticed several times that when cloning on a laptop, the Oculus will display with the wrong aspect ratio thus resulting in a skewed projection. We currently do not force the Oculus to run at its native resolution upon launching our demos like other demos do so this may be the case. Can you give me your exact setup as well? Thanks.
Oculus Rift Drift teklab Vizard 20 04-01-2016 07:57 AM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Oculus Rift Fullscreen teklab Vizard 6 05-21-2014 06:11 AM
Html and vizlink on Oculus HMD mshukun Vizard 3 10-30-2013 09:56 AM
Oculus HMD's setViewport() doesn't work jacky Vizard 1 09-25-2013 02:50 PM
