Old 11-20-2013, 04:05 AM
ChrisMa ChrisMa is offline
No textures in Vizard after exporting from Blender 2.69
Hello everybody,
I tried to load a Scene of a Supermarket after exporting it as a Collada from Blender 2.69. I found on http://www.blendswap.com/blends/view/67147
I'm able to load it in the Inspector and with a Phyton Script. But there is no Texture. I only the a black and White Picture and I can't see through the Windows.
What is the workflow with the Blender Version 2.69? I tried to Export it including the UV Textures and the Material Textures.
I'm using Vizard 4.10.00005
Thanks a lot.
Old 11-21-2013, 06:16 PM
After exporting the model do you see a sub-folder with textures?
Old 11-22-2013, 02:40 AM
It's not in a subfolder. Blender Exports them in the same Folder as the .dae file. I have to add, that the textures are not visible in Blender, before Rendering, too.
Is there still the Thing, that they have to be added to the mesh before exporting?
Old 04-16-2014, 09:24 AM
unfortunately I couldn't find a solution. If I generate objects step by step on my own and export them to worldviz the texture is exported and shown in worldviz (see attached screenshot).
Generating a subfolder manually with the name of the .dae didn't help.
Kind regards,
Christian
Any idea?
Name:	Texture missing.JPG
Old 04-17-2014, 12:36 AM
yesterday I opened one of the elements from this model http://www.blendswap.com/blends/view/67147 in a new Blender file. I had to manualy asign the texture to each face. After exporting this new model, I could load it in worldviz, with the correct textures on it.
But that's not the way it is supoosed to, I think
Exporting textures from Sketchup to Vizard Lithium Vizard 6 07-05-2011 11:24 AM
Applying textures to objects made in Blender andrewjworz Vizard 0 04-21-2011 07:15 AM
Vizard and blender 3d amartin7211 Vizard 0 11-12-2010 08:56 AM
Exporting from Maya to Vizard jfreeman Vizard 2 06-30-2005 03:14 PM
