Old 10-10-2013, 02:51 PM
Zhi Zhi is offline
How to apply texture on an on-the-fly 3d object
This question may be naive. But I could not find the answer in the forum or from the vizard help file.
I used vizshape.addCylinder() to create an on-the-fly cylinder. Then, I used <3d_node>.texture to add a texture on it. But, the texture does not appear on the top and the bottom circular faces of the cylinder. What shall I do?
Here is my code:
	tex = viz.addTexture('wood.jpg')
	tex.wrap(viz.WRAP_R,viz.REPEAT)
	tex.wrap(viz.WRAP_T,viz.REPEAT)
	tex.wrap(viz.WRAP_S,viz.REPEAT)
	circle = vizshape.addCylinder(height=0.15, radius=0.5)
	circle.texture(tex)
Old 10-11-2013, 11:40 AM
Zhi Zhi is offline
I think the problem is probably related to the texture wrapping. Because I can see texture on the side surface of the cylinder, but there is no texture on the top and bottom surfaces of the cylinder. However, the color of the top and bottom surfaces changed to the closest color to that of the texture I applied.
Old 09-01-2014, 02:15 PM
Notch Notch is offline
Did you ever find a solution to this? I'm trying to color an on-the-fly cylinder but am unable to get the color to appear on the top and bottom of the cylinder.
Old 09-09-2014, 05:42 AM
I think this might have been a lighting issue; without a specific light source, Vizard can make objects appear very dark in some situations. It's possible that the object was coloured, but I couldn't see the colour.
how to apply two textures to one 3D object? sqwiggily Vizard 3 03-15-2012 08:39 PM
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
Applying texture or colour to an on-the-fly object tomo_the_third Vizard 1 06-22-2009 12:12 PM
Move texture from one object to another Johannes Vizard 2 02-09-2005 04:55 PM
