Old 10-05-2013, 03:44 AM
sunil.nair sunil.nair is offline
Change the coordinates of .osg file
I converted a .obj file into .osg file and I am using it in vizard. I can see the objects in the .osg file but at a distance. I cannot bring it close. The .osg object can be moved vertically but not horizontally using the setPosition command.
Please suggest something.
Thank you
Old 10-07-2013, 05:43 PM
It sounds like the model might not be scaled correctly. If you open the model in Inspector you can see the size of the bounding box in the status bar. What are the values for the bounding box?
Coordinates change jincheker Vizard 2 02-08-2011 11:01 AM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
