Old 01-19-2006, 01:19 PM
Wenamun Wenamun is offline
Exponential Scaling
Hi.
My code scales my model (ball for now) with coordinates from my PPT system.
I would like to be able to scale the model quickly with very little movement from the PPT. Right now it's a one to one ratio.
I've used ppt.command(4.002)
to scale all my numbers by 2, or 5 or ten etc.
But I want exponential growth.
Thanks for any help!
Here's my code:
PORT_PPT = 4
ball.translate(0,2,5)
ppt = viz.add('vizppt.dls')
def ontimer(num):
data = ppt.get()
ball.scale(data[0],data[1],data[2])
viz.callback(viz.TIMER_EVENT, ontimer)
viz.starttimer(1,viz.FASTEST_EXPIRATION, viz.FOREVER)
-Wenamun
Old 01-23-2006, 09:11 PM
tobin tobin is offline
I'm rather unclear what you're asking for here, but if you're saying you want the size of the ball to scale exponentially with distance measurements from PPT, then you ought to replace the scale call with an exponential function of the PPT data frather than using the data directly.
Here's a good primer on exponentials:
http://mathworld.wolfram.com/ExponentialFunction.html
