Old 09-18-2013, 07:51 PM
thales thales is offline
Render synchronization
Hi everyone!
I'm running an application which requires a tight sychronization with the actual monitor displayed frames. Is there a way to get into the script a start of monitor frame event or a vertical sync flag from the graphic card?
Thank you all,
Thales
actual monitor frames, frame synchronization, vertical sync
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 07:45 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 11:20 AM
To Masaki regarding render nodes surf3rguy Vizard 1 04-17-2012 06:37 PM
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
