Old 01-09-2006, 11:41 AM
vanier vanier is offline
Send a message via AIM to vanier
Help with Vizard crashes...
Hello, can someone look at this and tell us why we are crashing. If we run the script for too long it will most likely crash and if we close it, it crashes for sure.
Thanks for your help,
Luc, Evan and Chris.
PORT_PPT = 4
viz.clearcolor(1,1,1)
#viz.add('tut_ground.wrl')
#ball = viz.add('white_ball.wrl')
#ball.translate(0,2,5)
ppt = viz.add('vizppt.dls')
ppt2 = viz.add('vizppt.dls')
ppt3 = viz.add('vizppt.dls')
ball.link(ppt2)
#the following modifies the model's appearance
toon = viz.add('toon.dlm')
ball.modify(toon)
def ontimer(num):
data = ppt.get()
#this one will make the model slowly transform
#ball.size(data[0],data[1],data[2])
#this one makes the model quickly scale
ball.scale(data[0],data[1],data[2])
pos = ppt3.get()
ball.lookat(pos,0,viz.ABSOLUTE_WORLD)
#ppt.command(4.002) # Scales all by 2.0
viz.callback(viz.TIMER_EVENT, ontimer)
viz.starttimer(1,viz.FASTEST_EXPIRATION, viz.FOREVER)
Luc Vanier
Old 01-12-2006, 03:08 PM
freeman1 freeman1 is offline
Hi Luc,
There seems nothing to be obviously wrong with your script that should make the system crash, other than the indentation after the timer, which was probably stripped out by copy/paste
PHP Code:
def ontimer(num):
data = ppt.get()
pos = ppt3.get()
Other than that, the ball you are referring to in line 16 was not defined previously, so you will need to uncomment
in line 7.
When running your script here with a PPT connected sending the position data of 3 points, the script runs fine and stable.
Is it possible that there are problems with Vizard due to your graphics card / computer configuration? Please make sure you use the latest graphics card drivers, update if necessary.
Also check if there are other USB devices connected to the computer that could cause problems.
