Old 08-14-2013, 06:12 PM
Question Possible to Unapply a shader?
Is it possible to unapply a shader after one has been bound to the object?
I don't see anything in the documentation about it, and passing in viz.OFF or similar values doesn't work ( kinda like how viz.OFF with <node3d>.texture removes it )
~George
Old 08-15-2013, 09:18 AM
You can clear a shader from a specific node using:
node.clearAttribute(viz.ATTR_SHADER)
You can also clear a specific shader from all nodes it is applied to using:
shader.unapply()
shader, unapply
Texture Coordinate Generation (TexGen) using Shader goro Vizard 1 05-31-2013 01:44 AM
Vizard Headlight in Shader shivanangel Vizard 1 06-27-2012 01:19 PM
SSAO Shader Implementation FranciscoPeters Vizard 2 10-08-2011 04:19 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
