Old 07-16-2013, 02:26 PM
slinkenauger slinkenauger is offline
Infinite Terrain
My infinite terrain is being displayed quite a bit below the origin position 0,0,0. I have tried set position; however, it doesn't work. Any ideas on how to get the terrain positioned where I need it?
Old 07-16-2013, 06:07 PM
I'm not sure how to add an offset to the terrain. Have you tried applying an offset to the viewpoint?
Old 07-17-2013, 06:10 AM
potentially, I could, but the problem is that when the tracking system is calibrated to 0,0,0, so I really need the terrain to be at floor position. Is it the default for it to be below the origin?
Old 07-19-2013, 11:49 AM
Are you linking the viewpoint to the tracker? If so, you can apply a postTrans operation on the link so the viewpoint is below the tracker:
viewLink = viz.link(tracker, viz.MainView)
#move the viewpoint 1 meter below the tracker
viewLink.postTrans([0,-1,0])
Old 07-22-2013, 11:53 AM
I'll give it a shot; thanks!
infinite terrain shahramy Vizard 0 11-05-2011 03:34 AM
Near and far clipping on infinite terrain vijaykiran Vizard 2 01-21-2011 05:59 AM
Plain Infinite Terrain + Sky kovitch Vizard 1 12-23-2010 01:09 PM
Infinite terrain code Saz Vizard 2 11-06-2008 03:32 AM
generate an infinite terrain vadrian Vizard 4 09-15-2004 02:09 PM
