Old 05-31-2013, 04:11 AM
krimble krimble is offline
vizact speak
Hi all,
I'm trying to make one of the "Complete Character Pack" avatars to speak. The thing is I keep getting the same error message:
Loading File: avatar2\casual15_f_highpoly.cfg
** Load Time: 0.59 seconds
** ERROR: Bone with name '' does not exist
** WARNING: Cannot run speech action on avatar, no face or jaw bone was specified
female = viz.add("avatar2\\casual15_f_highpoly.cfg")
speech = vizact.speak('jfk.wav', threshold = .1, scale = 0.7, sync = True)
female.add(speech)
In the .cfg file I saw the 3 available morphs. The blinking and eyebrow morphs are working fine.
How do I get the mouth morph to work with the vizact.speak function?
Thank you!
Kind regards,
Jeroen Derks
MPI for Psycholinguistics Nijmegen
Old 05-31-2013, 04:50 AM
Found the solution:
add to cfg file of the characterPack Avatar:
Under Material section:
head_bone = Bip01 Head
neck_bone = Bip01 Neck
head_mesh = casual15_f_highpoly.CMF
speak_morph = casual15_f_highpoly_talk.CMF
Old 03-19-2015, 12:48 AM
TheSwaine TheSwaine is offline
hi,
can you give a full example with the
in the cfg file and how to use it in Vizard?
I need to rotate the head_bone with a custom avatar and dont want to change the code.
cheers
Swaine
Old 03-20-2015, 11:20 PM
You can get a handle to an avatar bone in the Vizard script using the node3d:avatar.getBone command. Take a look at the animating bones tutorial for more on this.
The list of bones in the cfg file does not affect the getBone command.
making a Complete Character Set character speak Frank Verberne Vizard 4 05-25-2012 08:47 PM
After a using speak, model returns to idle animation? Enlil Vizard 4 08-06-2010 12:42 PM
Strange Speak animation and VRML rendering zoltantoth Vizard 2 04-19-2007 10:24 AM
Making an avatar speak while performing an idling animation vr_boyko Vizard 1 10-05-2004 04:23 PM
Using the 'speak' command with non-vzf heads bailenson Vizard 4 09-21-2004 02:24 PM
