Old 05-05-2013, 11:04 AM
whaleeee whaleeee is offline
Render Node View Matrix
I am trying to create shadowing effects using a depth map and a shader. My trouble now is getting the view matrix of my render node. If I do <node3d:renderNode>.getMatrix() is this the view matrix? The documentation is unclear and I am not sure how to verify this.
Also, what is the recommended method for passing this matrix into my vertex shader? The tutorial I am using says to store it in gl_TextureMatrix[1], but it is my impression that this matrix is read-only in GLSL. If I can use it, how do I set it in Vizard?
If I can't use gl_TextureMatrix[1], would I then have to use viz.addUniformFloat multiple times? addUniformFloat, I believe, only allows you to pass in a maximum of four float values.
Old 05-06-2013, 09:36 AM
After further research, getMatrix returns the transform matrix, so the view matrix is the inverse of this?
Old 05-06-2013, 10:26 AM
Yes, the view matrix will be the inverse.
render node, shader, shadows, view matrix
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 11:20 AM
Projection Matrix (onto oblique near plane) andrewjworz Vizard 1 07-13-2012 10:10 AM
To Masaki regarding render nodes surf3rguy Vizard 1 04-17-2012 06:37 PM
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
Documentation for coding a new render node? reedev Plug-in development 2 10-30-2008 11:06 AM
