Old 04-19-2013, 05:55 AM
andy_k andy_k is offline
Am I using 'ontimer' incorrectly?
I am very new to programming in Vizard, but I am a pretty strong .js programmer. I have an art gallery and I want a man to walk from picture to picture. He needs to wait for a few seconds at each picture.
So I have a number of walking sequences and I'm trying to use the 'ontimer' function to call the next walk sequence and also add a few seconds of delay.
It works perfectly the first time it is called, in dostuff(), but doesn't work at all in dostuff2(). I assume I am using 'ontimer' incorrectly, could anyone explain where I am going wrong?
Any help or advice would be hugely appreciated!
walkOne = vizact.walkto(4, -0.5, 4)
turnOne = vizact.turn(60)
walking_sequence = vizact.sequence( [walkOne, turnOne])
walkTwo = vizact.walkto(5.350, -0.5, -2)
turnTwo = vizact.turn(60)
walking_sequenceTwo = vizact.sequence( [walkTwo, turnTwo])
def dostuff():
male.addAction(walking_sequence)
vizact.ontimer(10,dostuff2)
def dostuff2():
male.addAction(walking_sequenceTwo)
print(vizact.ontimer)
vizact.ontimer(20,dostuff)
Old 04-19-2013, 09:34 AM
Instead of using timer functions you could insert vizact.waittime actions into the avatar's action sequence. The gallery.py world demo (Help -> World Demos) shows an example of that. Also, take a look at task functions, which are useful for controlling program flow.
I'm not sure if one of the vizact.ontimer commands is within a function. Please use the code tags to preserve indentation. If you only want a timer function to be called once, register the function with the ontimer2 command and set the repeats parameter to 0.
Old 04-18-2014, 01:18 AM
KoRnemuse KoRnemuse is offline
Hello everyone!
I post here cause I have a question about the using of ontimer.
I know that ontimer call a function but whenever I try to call a function which needs an argument I got an error on the type of my argument. It says 'Nonetype' object is not callable.
I precise that I created the argument before calling ontimer.
Here's what I want to do:
init = False
vizact.ontimer(0,suivi(init))
I can tell that my function is working perfectly because I tried it without the timer on.
Cheers KoRnemuse
Old 04-18-2014, 09:07 AM
In the future, please create a new post for your questions.
The vizact.ontimer command is expecting a function object as the second argument. Instead, you are giving it the result of calling the suivi function. You should just pass the function instead of calling it:
# Call 'suivi' every frame with 'init' argument
vizact.ontimer(0, suivi, init)
Old 04-22-2014, 07:17 AM
Thank you for your answer and sorry to up an ancient post.
I will ask an other question in a new post.
KoRnemuse
stopping ontimer durf Vizard 4 06-02-2009 11:38 AM
executable file with avatars incorrectly displayed aa-chris Vizard 2 11-03-2008 10:28 AM
