Old 04-17-2013, 04:16 AM
uncleseano uncleseano is offline
Collision Help
Heya I need help trying to get a ball to collide properly with a box and print out a generic statement. Need help badly thanks
boxes = []
balls = []
for i in range(GRID_WIDTH):
boxes.append([])
for j in range(GRID_HEIGHT):
#Add a box model
box = viz.add('box.wrl',cache=viz.CACHE_CLONE)
#Use the boxes bounding box for collisions
box.collideBox()
#Add the box to the list
boxes[i].append(box)
for x in range(MAX_BALLS):
#Add a ball model
ball = viz.add('ball.wrl',scale=(3,3,3),cache=viz.CACHE_C LONE)
#The balls collision will be represented by the bounding sphere of the ball
ball.collideSphere()
ball.enable( viz.COLLIDE_NOTIFY )
#Add the body to the list
balls.append(ball)
#Create a generator this will loop through the balls
nextBall = viz.cycle(balls)
breakerBox = viz.add('box.wrl')
breakerBox.collideBox()
breakerBox.setCenter(0,0,-2)
greenBox = viz.add('boxee.wrl')
greenBox.collideBox()
#greenBox.enable( viz.COLLIDE_NOTIFY )
greenBox.setPosition(2,0,-1)
#This function is called when a collision occurs
def ballBoxCollision(e):
if ball.intersect == greenBox.intersect:
print 'collision'
#if e.ball in balls == ground:
viz.callback( viz.COLLIDE_BEGIN_EVENT, ballBoxCollision )
Old 04-18-2013, 10:37 AM
Please post code using the code tags to preserve the indentation. You can find out which Vizard nodes collided from the event object e passed to the collision callback function. Take a look at the Event Reference page for more information.
If viz.COLLIDE_NOTIFY is enabled on the balls you can check to see if e.obj2 is the greenBox and you'll know a ball collided with it.
Physics: Ball Bounces Unexpectly Based Upon Size + Ring Collision Shape mhead10 Vizard 3 11-02-2012 01:44 PM
Main view collision problem AtomicRaiden Vizard 4 10-06-2011 11:48 AM
Collision Exception jassel41 Vizard 2 11-09-2010 05:08 PM
Collision and avatar animation shahramy Vizard 2 10-26-2010 11:47 PM
