Old 04-09-2013, 02:21 AM
fabioped fabioped is offline
Loading particle .osg on-the-fly
I want to do a smoke particle system which progresses over time in its size. To do that I guess the best way would be to change the rateRange of the RandomRateCounter in the attached OSG over time... How can I do that in vizard?
My aim is to create a water kettle that starts to boil and release more and more gas.
Old 04-09-2013, 03:06 PM
You could try creating several OSG particle objects with different parameters and then make them visible over time to create the effect that the smoke is getting bigger.
Moving / Rotating Particle Emitter, Not Entire System? shivanangel Vizard 2 02-15-2013 12:43 PM
Loading a 3D Texture shivanangel Vizard 16 01-25-2013 03:10 PM
Bulk loading avatars sleiN13 Vizard 3 07-17-2012 03:14 AM
Particle System... again... k_iwan Vizard 2 05-09-2006 12:42 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 04:44 PM
