Old 03-12-2013, 08:34 AM
andrewjworz andrewjworz is offline
Depth buffer
I need the depth information of each pixel, so I'm wondering if it is possible to render scenes in the z-buffer representation? (SEE figure at top of wiki article http://en.wikipedia.org/wiki/Depth_buffer ).
Andy
Old 03-12-2013, 09:11 AM
Even a method/plug-in for capturing the depth buffer and writing this data to a file would be helpful...
Old 03-20-2013, 08:29 AM
You can use a render node to render the scene to a depth texture and display it on screen. Here is a quick example:
viz.add('piazza.osgb')
# Add render texture using depth pixel format
depth = viz.addRenderTexture(format=viz.TEX_DEPTH)
# Use render node to render the scene to the depth texture
rn = viz.addRenderNode()
rn.setRenderTexture(depth)
# Display depth texture on the screen
quad = viz.addTexQuad(viz.SCREEN,size=200,align=viz.TEXT_LEFT_BOTTOM)
# Use shader to display depth texture in linear range
frag = """
uniform sampler2D depthTex;
void main()
	float d = texture2D(depthTex,gl_TexCoord[0].st).r;
	float n = 0.1;
	float f = 200.0;
	float z = (2 * n) / (f + n - d * (f - n));
	gl_FragColor = vec4(z,z,z,1.0);
shader = viz.addShader(frag=frag)
quad.apply(viz.addUniformInt('depthTex',0))
quad.apply(shader)
quad.texture(depth)
# Need to specify clip plane here and in shader
viz.clip(0.1,200)
Let me know if anything isn't clear.
Old 03-22-2013, 04:23 AM
This is great! Thanks!
Old 03-22-2013, 02:37 PM
Alright, one more question: Is there a way to size the quad so that is fits the exact dimensions of the window? I've tried, but I'm not sure how the 'size' parameter in viz.addTexQuad method translates into window coordinates.
I have tried inserting the following code into what you have written:
# Get window size
winsize = viz.MainWindow.getSize(viz.WINDOW_PIXELS)
quad = viz.addTexQuad(viz.SCREEN, size=1 ,align=viz.TEXT_CENTER_CENTER)
quad.setPosition(.5,.5,0)
quad.scale(winsize[0],winsize[1])
Old 03-22-2013, 02:54 PM
If you want to view it fullscreen, then you're better off implementing the shader as a post-process effect:
NEAR = 0.1
FAR = 200.0
from vizfx.postprocess.effect import BaseShaderEffect
class DepthEffect(BaseShaderEffect):
	def _getFragmentCode(self):
		return """
		uniform sampler2D vizpp_InputDepthTex;
		uniform float near;
		uniform float far;
		void main()
			float d = texture2D(vizpp_InputDepthTex,gl_TexCoord[0].st).r;
			float z = (2 * near) / (far + near - d * (far - near));
	def _createUniforms(self):
		self.uniforms.addFloat('near',NEAR)
		self.uniforms.addFloat('far',FAR)
viz.clip(NEAR,FAR)
import vizfx.postprocess
effect = DepthEffect()
vizfx.postprocess.addEffect(effect)
depth buffer
eMagin HMD Quad buffer problem Shay Vizard 1 11-30-2012 12:00 PM
Issue Getting Quad Buffer Working nabrahamson Vizard 2 08-30-2012 09:43 AM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 10:22 AM
depth perception for a DTI 3D monitor timbo Vizard 5 07-16-2008 12:23 PM
accessing screen buffer hotspur1 Vizard 3 08-22-2003 03:31 PM
