Old 03-07-2013, 10:10 AM
hzhao hzhao is offline
object on the fly--how to change color of particular vertex
With the following code, I created an object on-the-fly, a green polygon. Then I want to create a vertical transparent stripe, that is, set vertex 2 and 5 to be transparent. But the code doesn't work this way. Why? Thanks!
viz.startLayer(viz.POLYGON)
viz.vertexColor(viz.GREEN)
viz.vertex(0.0,0.0,0.0)
viz.vertex(0.5,0.0,0.0)
viz.vertex(0.6,0.0,0.0)
viz.vertex(1.0,0.0,0.0)
viz.vertex(1.0,1.0,0.0)
viz.vertex(0.6,1.0,0.0)
viz.vertex(0.5,1.0,0.0)
viz.vertex(0.0,1.0,0.0)
target=viz.endLayer()
target.dynamic()
target.setVertexColor(2,[0,0,1,0.2])
target.setVertexColor(5,[0,0,1,0.2])
Old 03-07-2013, 01:36 PM
What I want to do is to vary transparency within an object. How to do that ?
Old 03-20-2013, 09:42 AM
Many OpenGL drivers will internally break up POLYGON shapes into triangles. Try using QUADS instead.
viz.startLayer(viz.QUADS)
target.dynamic()
target.setVertexColor(6,[0,0,1,0.2])
target.setVertexColor(8,[0,0,1,0.2])
target.setVertexColor(11,[0,0,1,0.2])
Depending on your needs, you might be able to just use an alpha texture on a single quad to achieve the transparency.
object on-the-fly, transparent, vertex
Can I change the text size of slider object? jincheker Vizard 1 08-26-2011 12:20 PM
Possible to change size of a vizshape.addBox object? Renato Lima Vizard 1 10-18-2010 10:51 AM
get vertex with on the fly object enkeli Vizard 9 05-25-2006 09:27 PM
