Old 02-24-2013, 10:52 PM
atalantis atalantis is offline
Problems Ending Animation
So I'm running code so that an avatar runs a series of random animations one after another until the user signals the animations to stop with a key press. The problem comes up after the user has signaled the animations to stop. It stops the current animation, and then starts up a new one. This is even after I have told it to clearActions(). Perhaps I don't have a good grasp on how the action list works with the viz.FOREVER parameter.
teacher = viz.addAvatar('avatars/teacher/teacher1/teacher.cfg')
teacher.setPosition([0,0,0])
teacher.setEuler([180,0,0])
teacher.state(7)
def Start_Gestures():
	random_gesture = vizact.animation(vizact.randint(1,5), 3.0)
	teacher.runAction(vizact.sequence(random_gesture, viz.FOREVER))
def End_Gestures():
	teacher.clearActions()
	teacher.state(7)
vizact.onkeydown('s', Start_Gestures)
vizact.onkeydown('e', End_Gestures)
Any thoughts?
Thanks in advance!
Old 03-01-2013, 08:41 AM
tokola tokola is offline
atalantis,
as far as I know you cannot control avatar animations with the action library commands. Look for commands related to avatar animations. Examples are: <node3d:avatar>.setAnimationState, <node3d:avatar>.setAnimationSpeed, <node3d:avatar>.stopAnimation, etc.
I hope this helps!
Old 03-01-2013, 11:49 AM
The default idle animation for the avatar is 1. It looks like you want animation 7 to be the idle animation. Use the following to change the idle animation:
teacher.idlepose(7)
The avatar will automatically start this animation when the action action is completed. You can also disable the automatic idle animation by setting it to -1. This allows you to fully control which animation the avatar enters.
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
