Old 02-11-2013, 02:25 PM
jpriede jpriede is offline
"Launching in cluster master mode." when cluster mode disabled
Hello, I am running Vizard 4.06.0138 and when I run a script, it shows:
** NOTIFY: Launching in cluster master mode. Waiting for 12 client(s) to connect.
However, in Vizard Cluster Master, I have no clients selected, and "Enable clustering" is un-checked.
Is there a way to actually run it in standalone mode? I'm at a loss as to why it is connecting to my 12 clients.
Old 02-12-2013, 02:06 PM
Clustering can also be enabled through a config file. Is there a "vizcore.cfg" file in the same directory as your script? If so, try opening it and commenting out the line that specifies the cluster clients, "viz.cluster.master.clients".
Old 02-12-2013, 02:33 PM
Indeed! Farshizzo +1
clients, cluster mode, master
No rendering on Cluster Master victorqx Vizard 1 06-04-2012 08:42 AM
Automatically set Cluster Master Settings pcatalano Vizard 2 01-28-2011 01:09 PM
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 03:35 PM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
