Old 10-15-2012, 09:44 AM
Smile Vizard and SD2620W 26" Widescreen Stereo/3D Monitor
Hello Vizard Support!
I was hoping you could help me out a bit with a new piece of hardware we have in the lab. It is a Planar SD2620W 26" Widescreen Stereo/3D Monitor and I wanted to know if you have tested Vizard to work with this kind of setup.
http://www.planar3d.com/3d-products/sd2620w/
Right now I have installed a copy of Vizard lite on the workstation, but when I try to run the gallery demo with quadbuffer enabled, I get an error saying either the card does not support it or not enabled.
I am running a Quadro 5600 in the workstation, so quad_buffer should be enabled.
I have also attempted to use the NVIDIA control panel to turn on stereo, but I have not gotten any positive results.
Let me know if you have any suggestions!
George Lecakes
Old 10-16-2012, 09:00 AM
I haven't used this display before, but it seems to support separate inputs for the left/right eyes. Have you tried just using horizontal stereo mode (viz.STEREO_HORZ)?
Old 10-17-2012, 12:34 PM
Yes, and that was successful in displaying 3D using Vizard!
Thanks for the help,
George
quad buffer, sd2620w
