Old 10-03-2012, 01:09 AM
EKF EKF is offline
Windows vista issue
Hi
I have been using Vizard succefully to make a maze, and there were no problems running it. We have made a couple of changes to the maze layout, but using exactly the same objects and now there is an error message that says that the color scheme has been changed to Windows Vista Basic and that this is not compatible with certain elements of the program. Any thoughts?
Old 10-03-2012, 12:29 PM
That message is displayed when Windows DWM is disabled. Disabling DWM can improve the performance of 3D rendering applications, such as Vizard. Vizard 4 has an option to disable DWM. If you are still using Vizard 3, then it sounds like the file properties of winviz.exe were modified by somebody to automatically disable DWM.
If you do not want DWM disabled, then right click on winviz.exe, which is located in the Vizard/bin folder, and click Properties. Under the Compatibility tab, make sure Disable desktop composition is unchecked, then press OK.
Old 10-03-2012, 12:43 PM
EKF EKF is offline
Thank you very much.
Two-screen HMD on Windows 7 vasiliys Vizard 1 02-07-2012 12:22 PM
Spatialized sound in Windows 7 GiudiceLab Vizard 3 01-27-2010 07:35 AM
addText problems with 3 windows Ravi Vizard 1 08-25-2008 05:51 PM
Windows Vista Steve_HT Vizard 1 05-10-2007 10:30 AM
known windows firewall issue mspusch Vizard 0 06-01-2006 09:47 AM
