Old 08-10-2012, 12:56 PM
Trevor Trevor is offline
Cedrus Response Pad?
I'd like to use a Cedrus Response Pad RB Series for collecting response and timing data. I want to use it to replace simple keystrokes, but am not sure where to get started. Is there any documentation for using this with Vizard? Thanks.
Old 08-16-2012, 05:26 PM
You can use the vizcedrus module. To connect to the pad use the following:
#Connect to cedrus pad
import vizcedrus
vizcedrus.open() #Default: port=1 , baudRate=19200
Then you can register callback functions for button events:
#Setup cedrus callbacks
def cedrusButtonDown(e):
	print e.button,'button down'
def cedrusButtonUp(e):
	e.button,'button up'
viz.callback(vizcedrus.BUTTONDOWN_EVENT,cedrusButtonDown)
viz.callback(vizcedrus.BUTTONUP_EVENT,cedrusButtonUp)
HapticMaster + Vizard 4.0 SDK help pwsnow Plug-in development 7 03-03-2014 04:44 AM
integrating brain-imaging response buttons with Vizard hrm Vizard 1 05-04-2012 07:24 AM
viznet does not response! shahramy Vizard 3 06-16-2010 07:12 PM
IE cannot display form response page from python server Gladsomebeast Vizard 2 12-01-2008 10:12 PM
