Old 06-18-2012, 08:53 AM
snovob93 snovob93 is offline
Event control
In my virtual world I have three targets. When I touch the first target for the first ten minutes I want it to fade out and target 2 to fade in. However, after 10 minutes I want target 3 to fade in. If this is my script for the exit proximity for the three spheres, does anyone know how I can write the conditions in? All the targets (spheres) were created outside of the exit proximity.
def ExitProximity(e):
fade = vizact.fadeTo(0,speed=2)
sphere.addAction(fade)
fade2 = vizact.fadeTo(1,speed=2)
sphere2.addAction(fade2)
fade3 = vizact.fadeTo(1,speed=2)
sphere3.addAction(fade3)
Old 06-22-2012, 09:32 AM
When your callback function is called you can get the time the simulation has been running using the viz.getFrameTime() command. You can set up the condition statements with the returned value.
Old 06-26-2012, 11:19 AM
Okay, we were able to get it to work.
Next Question: Is there a way to get a timer to start when we run the script (That being time zero) and then record each time a target is touched from there? I thought I read it in a script somewhere, and now I can't find it.
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 06:25 PM
Camare control question(about separated eye view) atamasan Vizard 3 01-28-2010 06:22 PM
version control? billjarrold Vizard 1 01-26-2010 09:39 PM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
