Old 05-20-2012, 11:03 PM
goro goro is offline
Unhappy Flip WebCam input Horizontally
I am new to vizard working on Augmented Reality. I am trying to flip my Web Camera input horizontally. I am successfully flipping it but my system performance is going down. Here is my code:
video = viz.add('VideoCamera.dle')
ar = viz.add('ARToolKit.dle')
cam = video.addWebcam(type=viz.TEX_2D)
width, height, type = cam.getSize()
flipCam = viz.addBlankTexture([width,height])
width_3 = width*3
camera = ar.addCamera(flipCam)
dataCam = cam.getImageData()
dataFlipCam = flipCam.getImageData()
def mainLoop():
	for y in range(0,height-1):
		for x in range(0,width-1):
			dataFlipCam[(3*x+y*width_3)] = dataCam[(3*(width-1-x)+y*width_3)]
			dataFlipCam[(3*x+1+y*width_3)] = dataCam[(3*(width-1-x)+1+y*width_3)]
			dataFlipCam[(3*x+2+y*width_3)] = dataCam[(3*(width-1-x)+2+y*width_3)]
	flipCam.hint(viz.TEXTURE_MODIFIED_HINT)
vizact.ontimer(0,mainLoop)
Please suggest me alternate.
Old 05-22-2012, 01:28 AM
I have found the optimised way to flip the Image, Video and Web cam Input. Flipping is now not an issue but the issue is while flipping video & web cam images the colour changes.
This Image will illustrate what happens when I flip video:
Code for the above mentioned flipping video image
import Image
def PIL_TO_VIZARD(texture):
	image = Image.fromstring('RGB',[width,height],cam.getImageData())
	"""Copy the PIL image to the Vizard texture"""
	im = image.transpose(Image.FLIP_LEFT_RIGHT)
	texture.setImageData(im.convert('RGB').tostring(),im.size)
#Create a blank Vizard texture
tex = viz.addBlankTexture([1,1])
cam = viz.addVideo('mona.mpg')
cam.play()
cam.loop()
width,height,type = cam.getSize()
#---------------------------- Texture Comparison -----------------------------#
quad1 = viz.addTexQuad()
quad1.setPosition([-.75, 2, 3])
quad1.texture(cam)
quad2 = viz.addTexQuad()
quad2.setPosition([.75, 2, 3])
quad2.texture(tex)
vizact.ontimer(0,PIL_TO_VIZARD,tex)
Old 05-22-2012, 08:30 AM
Do you actually need the image data to be flipped, or do you just want to display the texture flipped? If you just want to display the texture flipped horizontally, then simply apply a negative scale on the texture quad:
quat.setScale([-1,1,1])
Old 05-22-2012, 10:38 AM
Red face Solved the Flip Image Issue
Thanks farshizzo for the reply. I actually need the Image data to be flipped. I am working on Augmented Reality Project & I want to create a Mirror. If I flipped the quad containing the Image then the marker wont get flipped, so the co-ordination between image & logo gets lost and mismatch happens. To overcome this issue I need help. I have solved the colour issue in flipping video image by modifying the code as shown below & got the output as shown in below image:
import Image
	RGB2BGR = (
		0.0, 0.0, 1.0, 0.0,
		0.0, 1.0, 0.0, 0.0,
		1.0, 0.0, 0.0, 0.0 )
	texture.setImageData(im.convert('RGB',RGB2BGR).tostring(),im.size)
cam.play()
cam.loop()
quad1.texture(cam)
quad2.texture(tex)
Old 05-22-2012, 10:59 AM
Angry Marker is not getting detected in Flipped Image
I working on ARToolKit & Successfully flipped the Webcam Image. But now the issue is Marker is not getting detected in flipped texture.
Here is the code:
import Image
#------------------------ Flip Horizontal ------------------------------#
def FlipHorizontal(cam_tex,texture):
	image = Image.fromstring('RGB',[width,height],cam_tex.getImageData())
	RGB2BGR = (
		0.0, 0.0, 1.0, 0.0,
		0.0, 1.0, 0.0, 0.0,
tex = viz.addBlankTexture([1,1],format=viz.TEX_BGR)
#Load Video Camera
# Load Web Camera & set cam as Video Texture
cam = video.addWebcam()
#Load ARToolKit
# Flip Video Texture Horizontally
vizact.ontimer(0,FlipHorizontal,cam,tex)
# Set ARToolKit Camera with cam as texture
camera = ar.addCamera(tex)  #---- This Dosn't work
#camera = ar.addCamera(cam) #---- This works
camera.setDebug(True)
# Add AR Marker
marker = camera.addMarker('ar/patt.hiro',width = 1000.00) #patt.hiro or patt.hiro_fh
#Add logo model
logo = viz.add('logo.ive')
#Link logo model to marker sensor
link = viz.link(marker,logo)
Old 05-29-2012, 09:20 AM
You need to flip the image before ARToolkit processes the camera image. Try scheduling the FlipHorizontal function with a lower update priority using the following code, instead of using vizact.ontimer:
vizact.onupate(viz.PRIORITY_PLUGINS,FlipHorizontal,cam,tex)
Old 05-31-2012, 09:50 PM
Nope.. Its not working...
I have even tried to set priority values from -1000 to 1000.
Old 06-04-2012, 09:40 AM
Is the incoming raw video data flipped or are you flipping it for another reason? If you are artificially flipping the data and the marker you are tracking is not horizontally symmetrical, then ARToolkit will fail to track the marker.
Old 06-04-2012, 12:13 PM
My webcam is giving real image & not the flipped image. But my application requirement is my customer should see him on screen as he is seeing him in mirror & marker should also respond in the same way. So can you tell me any alternate method so I can flip my webcam input out and out before applying it to artoolkit?
Old 06-05-2012, 06:07 AM
This simple code flips the texture but it doesn't solve the purpose..
ar = viz.add('artoolkit.dle')
camera = ar.addWebCamera()
camera.background.setEuler([180,0,0])
camera.background.setPosition([640,0,0])
marker = camera.addMarker('ar/patt.worldviz',width = 1000)
Marker positions miss match with the image if we go with this code.
Old 06-05-2012, 03:52 PM
You will need to "flip" the position/rotation values of the markers as well. You can use the link.swapPos and link.swapEuler commands to accomplish this. Here is some sample code:
#Add ARToolkit extension
#Create camera using first available webcam
#Flip background quad
camera.background.setPosition([camera.texture.getSize()[0],0,0])
#Create a matrix marker with the specified id
marker = camera.addMatrixMarker(0,width=1000)
#Add logo model
#Swap X position and yaw,roll of euler rotation
link.swapPos([-1,2,3],target=viz.LINK_POS_OP)
link.swapEuler([-1,2,-3],target=viz.LINK_ORI_OP)
Old 06-06-2012, 12:15 AM
Smile
Thanks friend! Its working.
artoolkit, camera, flip, flip horizontally, webcam
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 12:53 PM
Controlling User Input ohad Vizard 1 03-15-2010 05:16 PM
How to input several model files and then save one output file mspusch Vizard 1 07-15-2008 10:30 PM
problems with webcam plug-in v-clizzin Plug-in development 2 01-25-2008 03:06 PM
problem with input boxes shai Vizard 6 08-15-2005 10:51 AM
